Even the best laid out plans can go awry.
If anyone can recall .... I chose the 14 bolt hubs because of the smaller body that would allow me to retain a 5 bolt wheel pattern. The potential issue was the bolt pattern overlap between the 5 & 8 lugs. With the help of C&M Performance Machine in Michigan ( Hiya Mac! ) an attempt was made to convert it over.
Unfortunately, due to the hardness of the weld and the fact that the bolt patterns overlapped --- I ended up with cracks in some of the stud holes. Wheels studs are an interference fit and it was enough pressure/force to crack where the weld & parent material joined. :banghead:
Did I mention? :banghead: :banghead:
Just in case I didn't. :banghead: :banghead: :banghead:
One thing I didn't want to do ... was try it again. The failure was
not related to the work that C&M did, but rather the fact that we were tryng to do something that really shouldn't be done. So, the last thing I needed was ANOTHER failure. I clearly stated much earlier in the thread that I did not want an 8 lug pattern, and now I am required to run one.
A week of scavenging and emails didn't really lead to much success in finding what I was after. I only had one pair of DRW hubs ... all my other hubs were SRW. Thankfully Mac (
Hiya Again Mac ! ) had most of the parts I needed. A few roughly worded emails with vague blackmail threats (something regarding pictures, some sheep, and an oversized latex suit) had the parts coming to me
pronto. :angel:
So now .... I am the only idiot in North America with an 8 lug Dana 30. :looser:
Because of the different knuckles I previously installed .... the hubs were a simple swap involving 6 bolts. The only downside of this is that the 8 lug - 3/4 ton rotors & hubs made the front axle wider by roughly 1 inch per side. Mac machined me some 1/2 inch spacers for the rear to close the gap while still keeping the rear track narrower. A narrower rear axle (by a slight amount) improves your turning radius. Does anyone notice poor Mac has been roped into this buildup ?
I
know everyone is already snickering at the 8 lug Dana 30. :gag: I already had all the parts here at my place (with the exception of the new hubs required) so I haven't lost any money with this arrangement. On top of that .... I have aquired a free HP Ford D44. I will be shortening this axle at a convienent time in the semi near future. So when/if my Dana 30 breaks, it will be a matter of unbolting the knuckles and yanking the housing from under the Jeep. Then I can bolt in my new HP44 and continue on my merry way.
In my next post I will share a few photos and then continue on with the build up and explanations as needed.
I need to thank Mac from C & M Performance Machine for all his help. While he is a dirty scoundrel that enjoys laughing at my misfortunes (many that I haven't told here) ... he has helped me with parts location, great prices, and general input/advice. If any folks are looking for custom machining or HD driveline parts, defintely look him up. You can find him on Pirate 4x4 under the screen name "Mad Mac"
Just don't tell him I sent you ... he'll charge me more.
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
