MUDWEISER_XJ
- CENTRAL IL
Re: Project: The Silver Bullet
Mexican and proud. Hmm shouldnt that say american and proud? Just askin
You gonna be able to get everything done before the 2nd?
not as bad as i thought it would be. around 3k rpm's at what i think was about 65mphHow do the 4.56's with 30"s drive?
Lookin good sam. The rear should be a lot easier than the front. Gonna look good when you get it all done.
Bahaha sure. Leaf springs blow!
so after the transfer case with the SYE was installed, i started having bad vibrations, like riding a vibrator to work kind of vibrations. during the install 3 of the trans mount studs snapped and it currently has one.
is that the cause?
replace the trans mount and vibes go away?
is it causing anymore damaged other than shacking my ass numb? high priority?
SAM'sometimes rides a vibrator to work'SET
