So the story begins, I was looking for a cheap donor XJ to convert the project Lasr 2.0 to 4wd when I stumbled across this;
2000 XJ, NP231, AW4, 4.0L, upcountry suspension, full skids, trailer tow pkg, tow hooks, LSD and best yet, only 65kmi, thats right 65,326 miles, and its from the original owner of course.
only glitch it just needs a tune up.... or so he said...
so, I throw a code reader on it and get a misfire P0301, no big deal, swap the dead injector out, change the plugs test the coil pack, good to go, WRONG! what the heck??? next up compression test, of which cylinder one fails with varying compression of 0-80, while the rest are are 165-175. ok, maybe its a stuck valve, seafoam , Mopar CCC and... no improvement. Ok pull the head and find this...
Looks like a rat has been chewing on cylinder number one, The ring was partially seized in the area of the missing chunk. Alright no problem, I'll go to napa and grab a new piston, rings and bearings. Wrong again! no parts available in Hawaii, Thankfully I log on to Rockauto and BAM! good to go, parts are on the way and expected to be here today, only cost an arm and leg to ship.
In the mean time, i cleaned up some of the other engine parts, I'm thinking this jeep didn't get an oil change all that often, most of the piston oil rings and seep holes were clogged up.
Simple green is amazing stuff, let soak for about 20-30 mins then scrub clean with a scotch bright dish sponge.
BEFORE:
AFTER: (no.1 not cleaned, waiting on new piston)
and the gunk that was on the pistons:
simple green worked so well on the pistons, tried it on the intake manifold:
also tried something called TRR (toilet ring remover) to clean the rust inside of the coolant reservoir, worked great.
Before:
After:
and so it begins...
BEFORE:
Before:
After:
and so it begins...
