foxwar71
- Foxboro, MA
travis, you can come with me. well do a surprise visit to Bills, look at his jeep for a couple of hours, maybe watch him do some work, drink his beer, then go to joesph's
Ok... here you go.oh yeah, this update it worthless without pics!!!!!!!!!!!!
Thanks. I'll try to remember to snap a picture but on full bump the panhard is just about level and I have something like 3/8" clearance.Looking really good Bill :thumbup:It's hard to see in the pictures but at full bump you going to have any clearance issues with your oil pan and your panhard?
Thank you.Sweet build!
Assuming you mean the unirail side? No. Unfortunately due to the addition stretch if I were to extend the mount any further out I'd be into the coil spring. As it stands the back of the mount is flush with the outside vertical surface of the rail. This will allow me to box in the two tabs and have about 1/4" of clearance all the way around the rod end.Do you have any room to extend the panhard towards the driver's side?
Waiting for a few welds to cool I figured I'd run up quick and post my findings. From full bump to full droop the axle moves a total of 13/16" side to side. Meaning from ride height to one or the other the axle moves 13/32" side to side. I don't think this is a huge amount over the total 12" of travel. Also, once bump stopped and limited correctly the travel will only be ~11" so it'll be even less.... I'll see how much the axle moves side to side. I don't think it'll be any awful lot and it's not like I'll have to worry about bump steer. I'll post back with the results later.
Haha... I don't think so.The pinion yoke will clearance its self on the exhaust if need be.
I hadn't thought about ends yet. I was probably going to solder them on as I don't trust crimps. Otherwise I think I have a crimper large enough, thanks though!Got a crimper for terminals on that welding cable? You can borrow mine if you don't, it's only a harbor fright one but it worked great on the terminals I did for a ground cable a few nights ago. 2/0 die works great on 2AWG.
The "sealed" containers are vented with a tube to the outside. So I should be fine with whatever battery I chose to run. I've still got to purchase that too.Also - I would not put the battery in a sealed container, car batteries are wet cell lead acids so you'll have to worry about hydrogen outgassing if you put it in the passenger compartment or sealed container. Either that, or get an AGM or gel cell type battery and do whatever you want for mounting/sealing.
On the anti-crimp mentality - understandable, I used to think the same way back when all I had was a pliers-type crimper. I've got a lever type crimper for small wires and an 8 ton hydraulic crimper for large stuff now though, and I'd trust crimps made with these with my life. If you think soldering's better though, go for it, I agree soldered connections are great it's just a real pain to get full solder penetration on a stranded wire that large.I hadn't thought about ends yet. I was probably going to solder them on as I don't trust crimps. Otherwise I think I have a crimper large enough, thanks though!
Something along the lines of these but hopefully cheaper:
http://www.summitracing.com/parts/SUM-G1231/
http://www.summitracing.com/parts/TAY-48100/
Wow, mine's just a lever/pier type, not a hydraulic one.On the anti-crimp mentality - understandable, I used to think the same way back when all I had was a pliers-type crimper. I've got a lever type crimper for small wires and an 8 ton hydraulic crimper for large stuff now though, and I'd trust crimps made with these with my life. If you think soldering's better though, go for it, I agree soldered connections are great it's just a real pain to get full solder penetration on a stranded wire that large.
Battery housing - ah, you're way ahead of me then![]()
I've ordered some stuff from DelCity before, they are great. It's www.delcity.netBill, check out www.delcity.com. They have some quality stuff that you can use to make your terminals.
I looked and they have
-heavy duty copper terminal lugs : part # 907425
-solder slugs for the lugs: part # 900915
Thay have a video to show you how to make a perfect terminal end. Basically you drop the slug into the lug, heat the lug until the slug starts to melt, then while heating insert the battery cable and as soon as the slug is melted you just let it cool.
I plan on buying some for my winch cables so if you want some let me know and we can make one order to save money.
p.s. I am pretty sure that this is my longest post ever.
This post is hazardous to my wallet.Wow, mine's just a lever/pier type, not a hydraulic one.
I need to find a less expensive battery containment option.
I hadn't seen those solder slugs though. Watching the video it seems like they are stupid simple to use. I'll definitely be picking up a bunch. Along with some Side Terminal Power Connections, Copper Battery Terminals, Loom Clamps, Power Distribution Block or a Mega Fuse Holder with 250A fuse. The last two are unless I can find some better way to connect everything under the hood, I like the buss bars but not the price!), and a few other things. My biggest concern is the winch power feed. The plan is to run one 2AWG for the winch with some sort of connection that will handle up the the 460A Warn's site says the winch has the capability to draw. Then another separate 2AWG cable for everything else with that power block or fuse holder.
Edit: Looking around I found this Blue Sea 600A PowerBar that seems to be going cheap.
