foxwar71
- Foxboro, MA
So I got some figuring done today and I had someone remind me to take some pictures along the way.![]()
Ya, I guess I didn't explain it well nor did I post the correct picture to really depict what was going on. The first picture is at full bump driver's and ride height passenger. Not really sure why I posted that picture, I was tired last night.Remember that under articulation, the tire will get more into the fender than it will on straight bump - because the bumpstop isnt out where the tire is, the axle pivots on the bumpstop.
I always check linkage and body clearance at:
Full bump both sides
Full Droop both sides
Driver stuffed, passenger on the limit strap
Passenger stuffed, driver on the limit strap
Honestly like I kinda mentioned up top I havn't given it any thought yet, more worried about the rockers and the cage.how about incorporating a small bend in the track bar similar to the stock style in order to clear the top of the pumkin? a side shot would be handy too so you can see how much clearance there is front to back. what is the height of the panhard mount on the axle side?
just running with this thought, it would be better to put the adjustment of the panhard at the axle side if you were doing this because it would be the straighter end (by far)
what tubing had you planned on making the panhard out of? i'm sure it wasn't 1.75, but maybe you could bend up a small section of that and weld that to the rest... and the mount on the RE1665 is 2" wide... so it would clear that. just a thought. hope it helped.
I thought about that, nothing says it has to drop down from the driver's side. I moved the bracket over to see how everything worked (it won't with the RE, but thats not a big deal). Seems like it if I moved the bolt hole location up a little bit (approx 2" or so) on the frame side I would be alright other than it might be kinda short. Unless I mounted it high up on the diff cover, which I'm still up in the air about whether or not I really want to do that.What would it do for your packaging if you ran the panhard the opposite way?
Ya, I just might end up doing something like that. His did turn out pretty well, I guess I was just concerned about the cover bolts. It means I would have to sell my SOLID cover and buy something else, but thats not a big deal.It's been working out OK for Timmay for about a year now. :gag:
Bill, what about using something like the Ballistic fab frame side bracket and jsut make the mounting hole only like 2-3" down from the bottom of the frame? The RE mounts like 5.25" down IIRC, so why not just move that hole higher up to clear the diff? Something like the first pics in this thread...
http://www.naxja.org/forum/showthread.php?t=982973
For $25 thats a decent mount but the problem with Ballistic's lies in where they only offer 1.75", 2.5", 2.63" mounting widths and the joints that I bought are intended for 2.0" mounting. If I end up not cutting up the RE one, I'll probably just fabricate my own or get a RuffStuff one if I need to sell the cover and get something else.
Whether or not I have it drop down from the passenger's or the driver's side I will need to make a new mount. I think I should be able to cut the middle portion of the RE mount out and that should give me the clearance I need.
EDIT: Holy cow, I just looked up the price of the RE1665/RE1670 stuff, maybe I will just sell it and start from scratch!
Yeah. I'll hang onto it for now and when I get finished with the rockers/cage I'll use it as a template before I unload it.yeah, with the price of the RE stuff, i'd just resell it. build a piece similar to the Ballistic one and be done with it. you can get the clearance you need height wise, and then even push the mount forward a little bit to help with clearance of the front on the 60.
That would be great, thanks!I moded a stock bracket and have a SUPER low drop track bar bracket. I will see if I can rememebr to grab a pic tonight.
IMO, sell as pair and start from scratch. $ wise it's much more efficient. no need to cut up a 75 dollar mount..
