SanDiegoOverland
- San Diego
Ok, so I'm looking to change out my current power seats. My rig is a 1992 4door, so I don't have the option of putting ZJ/WJ seats in.
What I do have, though, is a set of manual, cloth seats from a 1995 rig in good shape. What I want to do is adapt those bases to my floor pan.
What I've noticed is that these seats basically sit flat, but have a 90 downward angle built into the front mounting tabs where the front mounting bolts are located, seen here in this borrowed pic:
Would you say that it be acceptable to simply trim those front angles off, and take a bolt straight down, through the feet, using a washer to keepthe bolt straight, or possibly heating and flattening the tabs to be used as mounting points?
