Tally_XJ
- Tallahassee, Florida
If you have lifted your Jeep, installed control arms, new steering modifications or other mods that has left you with a "wandering" Jeep that is hard to keep straight in the road, then I may have the cure you need.
I lifted my ZJ with RE 4.5" lift springs that gave me at least 5" of lift. I installed adjustable control arms, new adjustable track bars, OTK tie rod flip with all brand new tie rods and tie rod ends, checked and rechecked the alignment and I had a pretty bad "wandering" problem that I was unable to correct no matter what I did.
Well, I finally fixed it today.
I was just real sure that I had all of my control arm bolts tight, my track bar bolts tight and everything else under the front end tight.
I was wrong. I used an air gun to tighten all of these bolts when I installed the parts. Apparently that doesn't get them tight enough.
I used a 24" long ratchet in 1/2" drive and tightened the absolute $hit out of all of them. Most of them were loose enough that I was able to get at least a full turn or even several on some.
When I say tight, I mean tight. I laid the torque to these bolts and nuts.
Do this with the weight of the vehicle on the wheels so that the bushings are not torqued down then weight placed on them. This will cause the bushings to be twisted at ride height and will cause them to fail. You might even want to loosen everything then let the weight down on the wheels and then tighten everything again just to be sure.
My steering is now much tighter feeling and the "wandering" is gone. So are a lot of the noises I have been hearing up front; pops and cracks over bumps and when turning the wheels.
