filthyfingernails
- NE
Well I'm hopefully down to the last code to be cleared on my kid's "free" Jeep .
Her recently acquired 2000 XJ Sport I6 4.0L automatic trans. 4wd looks like its never been maintained (chick car). It has 150k miles on it but beneath all the crud seems to be a great Jeep. With CA emissions I had to install all 4 O2 sensors. That cleared up all the codes that had stacked up over the years. But this 0700 code won't clear. The XJ runs fine, shifts smooth.
I've looked at other threads and forums and usually the 0700 code is not alone. Some other failure seems to go along like a solenoid or gear ratio failure. This is just the 0700 nothing else.
What gives? Anyone? Anyone?
edit: Had no backup lights. I removed and rebuilt the NSS. still no BU lights. Then discovered that fuse #10 on the junction block was missing. Not blown, not on the floor... just gone. Replaced the fuse, bingo! Got backup lights. Code 0700 still won't go away. Tried clearing it, disconnecting the batt. cables overnight... no dice.
