Speed_racer
- Ft Myers, Florida
This Battery relocation project has turned into a PITA, not that ive even started, but that I keep getting mixed stories.
Ive got 20ft of wire, something between 0 and 2 gauge for the power.
This is going on a 93 XJ 4.0
The way the battery is now, 2 wires run to the positive terminal, one from alternator, one from Starter.
And 2 wires run to the negative, one to the block, and one to "chassis"
My plan is, change out the wire from the alternator and starter with the 0/2 gauge, and run them into each other, run that SINGLE wire from their to the back of my XJ to the positive on the battery.
From the battery Run the negative wire (about 4 or 6 gauge) from inside, thru a hole (lined with a grommet so it dosnt cut it) to the "chassis"....
Is this the correct way to do this?!
How important is it that the ground wire goes into the block?
And lastly,
Someone told me run the ground thats hooked to the block to the chassis, WHy would that matter?
TIA guys!!
And lastly,
TIA guys!!
