Uni
- Baldwin Park,california
Hello all,
Im new to the forum, but based on what I've read so far, I know that if you all can't help me find the problem than I just might as well get rid of the xj. Here it goes... I've got a 91 xj with 6" lift. The lift is made up of
skyjacker springs,
Rusty's control arms,(upper adjustable, lower fixed)
Skyjacker droped pitman arm,
skyjacker adjustable trackbar,with steerig stabilizer,
rusty's shocks,
home made sway bar disconnects(extended)
the rear is as follows...
Rear springs w/ AAL
3" block
2" shackle
custom drive shaft
t-case drop bracket/washer.
I'm running 33" big O tires on Steel chrome rims.
After a offroad trip the track bar got loose and I experienced my first death wobble at 70 mph. I tried having the vehicle aligned but it didnt do any good, in fact at 7* caster its very loose, im running approx 2-0 right now with little success. the tires were balanced the upper control arms changed, the steering lincages changed, the shocks changed, the pitman arm put in, the whole lift is about 6 months old. I can't find the problem, and neither can anyone else. Please help.
skyjacker springs,
rusty's shocks,
Rear springs w/ AAL
3" block
2" shackle
custom drive shaft
