Badmunky
- South east Michigan. (For now)
So in November I bought a nice clean 2001 XJ.
It has had a lot done to it already. Some good. Some bad. Some things just not my style. But its solid, and runs and drives great!
Ill start of with a list of whats been done to it. Then I will get in to what I need to do to it. In the order I plan to tackle things.
Here are a few pics for you guys.
Yes that lift block/ spring mount is welded to the axle. No it will not be staying like this!
So here is what has been done to it so fare.
Custom long arm kit. Looks to be well built and solid. I'll post some pics later.
Custom front bumper. Vary beefy! Not my style tho. It will be replaced.
Custom rear bumper. Again beefy! But not my style. Will be replaced as well.
Custom roof mount spare tire mount with high lift jack. Again not my style, will be removed.
Longer brake lines front and rear.
3" lift springs and shocks up front from Skyjacker.
3" add a leaf in the rear also from Skyjacker.
New rear shocks and axle mounts. No idea what they are.
Chevy Corporate 12-bolt out back. (Narrowed with custom mounts.)
Chevy D44 converted to drivers side drop up front. (Narrowed with custom mounts.)
Axles are from a 77 3/4 ton Chevy. PO got them for free.
PO "Claims" it has 4:11 gears, and that the axles where rebuilt with all new seals and bearings 8K miles ago. I say "Claims" because based on 4:11 gears and the tires that are on it it should be just as fast as it was stock, and the speedometer should be almost dead on.
Its slow, and the speedometer is off. Reads 62-63mph when your going 55mph. I think they changed the speedometer gear in the T-case, and used the wrong one at that.
It has almost new 16 wheels and 265/75/R16 Goodyear Wranglers on it. They have about 1,700 miles on them.
The Jeep has had an epoxy coating put on the floors and lower doors.
Optima red top that I think is about done.
And the PO just replaced 2 of the O2 sensors before I bought it.
Ok so the first problem I have to fix is the steering box, lines, and pump.
The box has play in it. And is leaking from the output seal a little.
The return line has a leak where it is crimped.
And the pump has 144k on it, and it hums a bit. So I'm going to replace it when I replace the rest of the system. Just kind of make sense to me.
For the box I am going to use one from a 2001 S10 4x4 V6. This is basically the Durango box upgrade, but the S10 box uses brass bushings in place of the Durangos plastic bushings. It also has a better ratio for off road, and is rated for higher pressure then the Durango box.
For the lines I am going to modify the stock lines from a WJ.
For the pump I am going to us the pump from an 01 Grand Cherokee 4.7.
Its a bolt in for me seeing as I have the newer style pump mount. It flows more fluid at higher pressure then the stock pump. Should make turning big tires a little easier.
If you guys see any thing wrong with this setup please let me know.
My next project is the exhaust system.
I have none of this planed out at this time.
I know what I need to replace, and what I want. But am not sure how to get there just yet, and what parts to use.
So here is what I need to replace.
EVERY THING. Block to bumper. Its all shot.
Here is what I want.
As much power improvement as I can get, without spending every dime I have. And something that will sound good, but not to loud. (It needs to last 2 years or so and still look nice so I can sell it when I swap in a GM LS V8.)
My Jeep as the 2 pre cats. And the main cat. Also known as the California emissions system.
I want to convert it to the federal emissions system that dose not have the 2 pre cats, but I don't want to end up with check engine lights (CEL) ether.
This thing is not used on the street much if at all. I don't have emissions testing here. And if I put 1,000 miles a year on it Ill be shocked!
So I'm good with removing most of the emissions system. I will still run the main cat. Tho I will replace it with a new high flow one.
My next project will be the suspension.
Starting with the rear. I plan to cut those lift blocks off, and install new mounts, springs, shackles, shocks, shackle relocation brackets, and a U-bolt elimination kit. Ditch the sway bar. And replace the bump stops.
The front has the same problem in that the PO raised all the mounts about 3.5" when he installed the new axles. So I will need to redo all those mounts as well. I will replace the springs, shocks, and add sway bar disconnects as well. New bump stops, and a new adjustable track bar will finish the front off. Currently it still has the stock track bar, tho the mount has been moved up 4.5"s, and to the left a little to re center the axle. NOT the best way to do it.
There is a lot more I plan to do but that is what needs to be done this year for sure.
So what do you guys think about the Exhaust system and steering system?
They are top of my list right now as I can not really drive the Jeep until there fixed.
The suspension will need to be addressed before I take it off road as well. But that I have mostly figured out.
Thanks guys!!!!!
Thanks guys!!!!!
