Photoshoot: Bam Margera's Lambo & My Camaro
I still think it's amazing that they started out making tractors (Lamborghini)....didn't realize they are owned by Audi/VW now....
...Hella 90mm projector modules (low beams) & Hella 90mm Free Form modules (high beams), Hella custom 12 gauge headlight wiring harness with relays and fuses....
sweet Camaro
would you happen to have any light pattern/cutoff pictures of the 90mm projectors handy?
is that a pair of Hella Micro DE's down below?
So you took pictures parked next to some rich guys car and called it a photoshoot?
Nice Camaro though, I was looking at picking one of those up a few years back, ended up with a Mustang instead.
Being a paparazzi would be fun, but too stressful at the same time. I do enough photojournalism with local Fire & Vehicle Accident scenes ;-) Though, living in LA, I could be making 6 figures easy if I learned the ropes.
I put "photoshoot" in quotes for just that reason Islander, lol. And thanks for the Camaro comments.
sweet Camaro
I do have a whole writeup on it... clicky:
http://www.ls1tech.com/forums/appearance-detailing/931991-projectors-finally-installed.html
awesome! thanks
if you ever happen to stumble across a drivetrain+harness from a 98-02 Camaro aka ls1+t56 that is in the NJ/PA area. Theres a finders fee in it for you :cheers:
I used to want a Lamborghini when I was younger.......till I sat in one, not a good fit.
The new stuff is light years better than the old crap they used to make like the Countach, Diablo, etc. The modern stuff are "real cars".
Cool find, too bad Bam is a bit homo looking with all the makeup and everything (and a purple car). Kudos to the guy on his success, I guess he is the definition of a self made man.
As far as the camaro goes, when you consider bolt ons, don't forget about the class changes you will be required to make with each mod. Springs, tires, bolt on subframe connectors, and I think even headers will let you stay in "street prepared" or ESP, but heads or a camshaft and you are looking at "prepared" or CP, which is basically for gutted out race cars that get trailered to the track. Check the SCCA rule book before doing your mods, or you will be taking them back off to drop class, buying more expensive race parts to be competetive, or losing badly to the prepared cars that are far more modified.
