87Bertone
- Danvers MA
Greetings -
I've got a quick question regarding removing the axle on the passenger side. (I need to remove the axle to replace the u-joints).
I removed the drivers side axle/hub assembly last month without many problems, but I'm curious if the procedure is the same for the passenger side axle.
Will the locking hub disconnect etc that I understand is on the passenger side cause any issues? Any insights are deeply appreciated before I get out the BFH and get busy!
Thanks
Dan
96 Cherokee
Thanks
Dan
96 Cherokee
