I am having a problem with my '96 Cherokee. When my RPMs rise to 3000 or higher, my Cherokee's electrical system rises to ~18-19V. When I drop RPM, the voltage drops back to normal operating voltage. I know it is not a bad gauge reading because when it goes into over-voltage condition, the A/C blower fans turn into jet engines and the light behind the gauge cluster turns into a spotlight. I have also noticed the charging system won't over-volt after a cold start until the engine has warmed up.
So far, I have cleaned both battery terminal posts. Cleaned the positive battery cable terminal and replaced the ground terminal. I also checked all ground and alternator cables to ensure they are snug. Where should I go from here for troubleshooting?
