Overheating or normal?
Thoz43
I have not Confirmed, or I used a BAD email Addy
California
Alright guys, I’ve done research for months now, and I could find nothing that described my issue. My uncle and grandfather, who used to race an XJ were stumped as well, so here I am hoping someone can help me.
The XJ, 1989 Laredo 4.0 with only 84000~ miles on it. Bought it in 2023 on non-op with 74000~ miles and fixed it up and its my daily since. It goes back and forth breaking stuff.
The issue. Overheating. Since owning it, I have replaced the waterpump, thermostat, radiator, fan clutch, and electric fan, and I have cracked 2 separate coolant reservoirs, most previous one about a week ago. Back in Janurary I installed an electric fan switch just to switch it on when I start it up. It ran great for about 5 months. At 75~ mph I would be at about 190-195° and idle at 210°. The other day, I was driving home, and my coolant reservoir cracked and coolant spewed everywhere. That, and along with one of the “T-fittings” which connected my thermostat housing to the top hose on the coolant reservoir. Today I put on new parts and the Jeep idled at 245°~ and at about 40~mph (neighborhood) it was 210 and would surge back up. I had the heater on and it didn’t make a difference. Im in California and today it is about 99° outside. I should probably mention I did not drain the radiator or block of coolant when putting on the new reservoir. What could my problem be?
Went outside to check the reservoir level, its empty and has dirt layered on the bottom. Does this indicate anything?
The RENIX era coolant reservoir has its issues. I'd convert to a later open reservoir. The red stuff is probably rust in the system. I'd do a flush. I forget what ones I've used. Red Devil and there is another that does well on rust. A bit expensive though.
The cap on the pressure tank is a known failure point. The replacement tanks flex and the poorly made caps tends to not hold pressure or work loose, causing a loss of pressure and a boilover. I had one that would open a 6-psi. A cap for a 710 Volvo has much better formed threads and holds pressure correctly. If you replace the radiator, I highly recommend converting to the open setup from a 92(?) or later. Get heater hoses for a 96+ to eliminate the failure prone heater control valve.
When filling, I like to loosen the temp sensor at the back of the head to let the air bubble out. 1/8" hole at the top of the thermostatif it doesn't already have one to let air bleed through also really helps.
So it sounds like with my new reservoir, I should purchase the Volvo cap and be good to go? When the Jeep is running, the coolant is bubbling into the reservoir. Is this because of the poorly made cap?
