- 12v to O2 restored (Engine needs to be running, maybe was never lost)
- Pulled O2 sensor had a bad heating element, I replaced it with a back up I had that tested good.
- fixed doughnut, I did smear a bit of copper RTV on so, I gotta let that cure before I run it.
- Contemplating re smog test prior to engine running O2 test.
- Going to new "more forgiving" test center that will put about 10 freeway miles on her before test, the other one may have been too close (2-3 miles, no freeway) for things to heat up, especially if the O2 sensor was not pre-heating.
- If it fails again, I have 30 days, to re test for free. (O2 sensor engine running test, other sensors, compression test, etc.)
- Problem is I guess I don't really know how to back probe reliably without damaging the sensor.
