one piece oil pan gasket
NAPA.... there is a rubber one piece for the 1993 engine... I used it on my 89 engine... worked fine. around $20 I think... well worth it.
~Joe~
Go to 4wd.com and input oil pan gasket into the search box - that's the one you want. It's a one-piece rubber gasket with metal inserts.
You have to ask for a 92 or newer cherokee motor gasket,same size for older block.Not sure about national chain parts stores,I use independent parts store.
