poorboy87
- Linton Indiana
It helps them quite a bit. All chains are gunna stretch
So basically you are a askhole? Those compression numbers are great especially for that mileage. That's a engine that will run for another 200,000 no problem, funny you'll trust a reman which has a known issue of never running as long as the original motor even though you have one that has proven the test of time and is still kicking strong...
IF I had the time to leave this XJ out of service,the head and timing set would have been repaired/replaced as necessary,,,,,but I don,t.
Sort of hard to believe that his 400k XJ is a car he can't leave out of service. I guess this is his only car? Even if the engine was running great why think that anything else couldn't leave you stranded on the road. Sounds like it is time to find a new DD.
You must be under the impression that everything on this XJ is the same age.
Only the motor has been untouched,
It is my only Jeep.
I dunno but I'm sad to see a good tried and true engine get yanked and replaced with an engine with unknown mileage expectations. If it were me, I'd get the head redone and a new timing chain and gears and new lifters and be done with it.
And as a side note, I also was running 4.10's and 33" BFG KM2's and my engine only has 230,000 and had trouble keeping speeds. Since I went to 4.88's I don't have those problems anymore and only turn just over 2600 rpm at 70, and 2400 rpm at 65, not 3000+ rpm.
At 4000,000 I would see how far it would go and I would be proud of that engine! I would even slightly boast about it knowing that 99 percent of other manufacturers engines will never see those kind of miles. Just my opinion.
I totally agree with everything you said....but as far as the original poster goes, I figure "Not my circus, not my monkeys". This thread has been really helpful for me though, considering I am getting close to 300K.
The timing chain replace was really beneficial...next step for me is to check compression. When the time comes, I will probably just opt to replace the head rather than a rebuild.
