Original_MudButt
- In the eighth dimension
Catalog shows two O rings to buy ?
I think there are three. One large one and two smaller ones.
I replaced them on my 94 a few months ago. There were 3 in the package that I bought at the local dodge dealer.I think there are three. One large one and two smaller ones.
Since changing the OF adapter o-ring is not a frequent repair, is anyone intersted in selling their fabriacted tool? I need to change my o-rings but have no way of fabricating.
I have an 2001 4.0 if there are any takers.
I used this method a month ago and it worked great. There was little room on my 2001 and the whole socket and breaker bar had no chance of fitting.buy a T60 socket bit,
http://www.ebay.com/itm/MAC-tools-1...e-Socket-VERY-NICE-/300936850922#ht_45wt_1141
hammer out the bit itself from the socket part, then use a 12mm wrench on that.
Ok,I bought a 5 buck T60 bit. I punched the bit from the 3/8 chrome "socket', then cut the end from an unknown typical L shaped lug wrench and welded the bit to the end. Had to heat this hillbilly wrench to put a bend in it for best clearance to miss AC hoses etc.. Put a pipe over the end for a total length of about 3 feet and "jerked" the bolt loose .I would estimate it was at least 120 ft lbs...
Two questions, do these adapters always develop leaks over time? We have two 99 XJ's and both leak ( the screw on filer is not leaking)
I'm not sure it's that they were torqued on really tight but that the factory mighta used LocTite on the threads. Perhaps you will see some chalky residue on the threads upon removal..
I haven't yet - not on RENIX. Dunno about ChryCo.
