97 XJ 4.0 - Anyone had this problem... my oil filler cap won't come off. It's acting like a child-proof bottle cap when I try to remove it. It clicks and will not twist off. I know it does this when you tighten it, but mine is doing it when I try to remove it. The engine is slightly warm.
Also, if little bits of plastic from the cap are falling off under the valve cover as I'm doing this, will they necessarily cause problems when I run the engine? I hope I don't have to remove the cover.
Thanks in advance.
Thanks in advance.
