Hickey
- Magna, Utah
Would a faulty O2 sensor prevent or seriously hinder startup? Would a bad O2 sensor always throw a code?
MY 92 XJ with 4.0 and auto sometimes starts right up with little cranking, but lately, most times it will crank for quite a long time(minutes) finally start, run rough for a few seconds, then quickly smooth out. On accelleration, it will bog and surge. Seems if I keep a steady throttle pressure on a level road, it will run fine.
I can hear the fuel pump when I turn the key on, but not everytime. Once it primes, is there something that tells it to stop pumping? I have already bypassed the Ballast resistor. I have also changed the filter. I can feel the fuel line from the tank to the filter vibrating while it is running, it isn't perfectly smooth, has some slight surging/pressure changes to it when the engine is running.
