Nv231c Hd
BrokenXJ
Massachusetts
I was the junk yard this morning getting some stuff, and found a
NV231C HD already pulled. I know its chevy, but how much stronger is it? and will to bolt up? because I can get it for $50.
I'm not sure about the 231c but I put in a 241c and 1 mounting hole was offset and couldn't be used. the clocking was slightly different. I had to cut a hole in the floor, to keep it from hitting the body, but I don't have the stock crossmember. I did a belly tuck. I think if the input splines are the same it would bolt in, you would probably need at least a front shaft. the chevys use the flange style. But maybe you could use the front output yoke from your jeep t-case. Check out the nvg sight.
www.newventuregear.com/tcases.html
Have fun
chadc
