Nut Strips for the muffler?
hitchhiker
Wake Forest, NC
Do both of the bolts holding up the rear most exhaust hanger go though the nut strip?
I'm halfway into installing a new hitch, I have the drivers side ready to go with the pull though bolts and square washers from quadratech.
Can I use the 3 square washers to remove the rusted out nut strip on the muffler side too or do I need to get a new nut strip? Theres a bolt for the muffler that is further up from when the hitch mounts, not sure if thats the nut stripe or not that far up.
Quadratech sent me a bunch of hardware so I have enough washers at my house already if I can go that route, otherwise I guess I'm looking at buying a new nut strip to replace the rusted out one.
You can remove nut strip and use the shoulder bolts square washer no problems.Although nut strip is probaly a better setup.On a side note how do you keep from pushing the bolts back into the frame when installing hitch.
