Mr Clean 1
- Baltimore, MD
Hey, y'all, my '01 limited is throwing codes P0161, 0155, 0141, 0135, both up and downstream o2 sensors causing havoc. Between NTK and Bosch, which is a better choice?
Regarding NTK, I have 3 of the four o2 sensor part numbers. The only downstream o2 number I was able to locate is NTK #23099. The two upstream part numbers are #23151 and #23506. Are the two downstream part numbers the same #23099?
Bosch o2's have 4 part numbers for the '01 XJ #13122, 13138, 15465, and 13100. Who's the better choice or is there another o2 I should consider?
Also, if my cat was bad/clogged due to the o2's failing, wouldn't I see code P0420? It was replaced in Jan. 2019. Thanks, y'all
atriot:
