muddshutter
- Fighting Giblet Burg, Va
Jeep Comanche 87/97
Virginia Inspection
Less than 300 miles on everything
Since everything is new or has been replaced
Truck was purchased for $2000
Was featured on a popular website before purchasing.
http://www.4x4wire.com/jeep/projects/comanche/
Short bed, bed liner, interior has truck bed coating under the carpet, TJ floor plugs, new headliner, new sun visors.
7.5 inches of lift overall
4.6 Liter Titan Stroker Engine $1950
24 lb injectors & Champion plugs
Flowkooler water pump $100
3 core radiator CSF $200
twin electric fans 5k total air flow $200
Poly Tranny mount $45
Rusty’s air intake
K&N cone filter
Firepower ignition system $175
All new sensors, hoses, belts, plugs, etc $600
New valve cover and oil pan, upgraded oil filter
Centerforce clutch $299
M.O.R.E. bombproof rubber engine mounts $130
M.O.R.E. bombproof Block Brackets $240
AC lines removed
Ax-15 external slave, Rebuilt Professionally and
shifts smooth, new shifter knob $600
New Starter $35
New alternator $75
NP 231 Completely rebuilt with SYE & Novak conversion $400
Tom Woods Front & Rear driveshafts $400
Pacesetter exhaust header $200
Flowmaster custom made exhaust with New Cat $250
5 - 35” x 12.50 x 15 BFG Mud Terrain tires $900
5 – Pro Comp Black steel rims with chrome centers $175
Rock Rats black lugs $20
97 XJ front grille, fenders, silver star lights, and mirrors $400
ARB bull bar front bumper with aluminum fairlead
Mile Marker 8000 pound Winch $400
Synthetic line 3/8” x 150’
Custom made rear bumper with 2" receiver mount
New glass: $300
The windshield is brand new with a light tint, New regulators on both door windows, new rear glass with slider and lock, new rear view mirror
Dana LP 44 rear axle: $1200
ARB air locker, professionally installed with Alloy USA 4:88 gears & 30 spline USA Alloy shafts, new bearings and seals. All outer axle connections have been welded. Tera-flex rear disc brake conversion, new brake pads and rotors with braided brake line and proportioning valve.
Dana HP 30 Front Axle: $1100
ARB air locker, professionally installed with Alloy USA 4:88 gears & 30 spline USA Alloy shafts, new bearings and seals. All outer axle connections have been welded. New brake pads and rotors as well as braided brake lines.
JCR 1 ton steering upgrade, professionally installed. $400
JCR Stage 2 Rock Sliders $250
TNT steering box reinforcement $150
TNT Customs Y link long arm system and Adjustable Trac Bar $1300
Uni-body frame stiffeners/frame skids $250
3 Rear frame stiffeners. These support the gas tank & E-brake, allowing the bed to be removed without taking the tank out first. $100
ACOS front spring adjustable spacers $200
6.5 inches lift front springs $110
JKS bar pin eliminator set for front shocks top & bottom $150
4 - 10” 5150 Bilstein shocks with remote resivour $400
Alcan rear leaf springs, custom made $400
Rock Krawler boomerang 1.5” - 2.5” $100
Gel cell battery
Free Motorola handheld CB new in the box
I am moving for a new job and i cannot take this with me. I want to, but i really cannot. The Jeep is almost done. The winch needs to be hooked up but is already in the bumper. The truck needs to be primed and painted. I have MANY extras that i will throw into the sale, for free. I have left out many little things that are brand new and certainly come along.
Photos will come as day breaks.
Virginia Inspection
Rusty’s air intake
K&N cone filter
AC lines removed
New Starter $35
New alternator $75
New glass: $300
Gel cell battery
