non xj: 91 yj disco dana 30 3.07 gearing
crash02
I bought a disco dana 30 complete disk to disk out of a 91 wrangler just for the lock rite. I have the stock spiders that I'll put back in after I pull the lock rite.
other then some surface rust, brake Rotors and pads look new.
Just looking to recoupe my gas money to pick it up.
40.00 takes all(minus the lock rite :D )
I'm surprised it was still there, until I tried pulling the lunch box locker, darn springs and pins. almost out.
The hub bearings look fairly new also, there is still clean steel where the rotors were.
Ok lunch box locker is out and original spider gears are in(diff cover bolted but not sealed and no fluids). I forgot to also mention it has the steering links and pitman arm from the yj. Rotors, pads, calipers brake lines(longer then xj lines), axles (inner, outers, and stubs)and hub bearings should Work as extras, spares, or replacement parts for all d30's with the exception of the disco axle parts only working for other discos.
