I'm looking at buying jeeps, and I want a 5spd so my results are quite limited. One of the best deals I've found has a 6" lift and is running 33s. I'm trying to figure out if this would be able to pass the NJ inspection.
I found a list of requirements here http://www.the-jersey-devil.com/bbs...er=21201&page=0&view=expanded&sb=5&o=&fpart=1 and the only real concerns besides being limited to 9" of increase over stock are numbers
10 - Front fenders must extend over the full width of the tire tread. Rear tires that are not covered by the fender or other body parts must be equipped with metal protectors or flexible flaps that prevent dirt, debris and water from being thrown - It has large flares that looks to cover the tires completely (give what I can tell from pictures), but how much of a stickler about this are they?
13 - Ballast must be securely mounted. -What is this talking about?
14 - Releasing the steering wheel in a sharp turn shall result in an increase in turning radius. - I'm not sure how this would be fixed in the event it failed because of this.
Also any tips on passing the tilt test? Or should it be no problem if everything is installed properly? Thanks guys
