Newb
Kevin G
WI
Hello everyone my name is Kevin and i am from the Madison,Wi area. I was just wondering if there was anyone else around here that is on here. And a quick question that i could not find, what is the highest i can safely lift my xj before need a LA conv.???
That is a loaded question. What are you building your jeep for? How tall are you wanting to go?
Generally you can get away with 4.5" lift without long arms or drop brackets, your control arm angles get pretty steep after that.
Welcome to NAXJA. There are quite a few members in Wisconsin and a couple in Madison if I remember correctly.
Kim
I'm in the LaCrosse area which isn't too far from ya. I think most people switch to long arms at about 4.5 inches of lift or start using drop brackets then to get back some of the ride quality. To be honest, wheeling a stocker is still alot of fun and you actually get to learn what it can do so you will know what needs modifying. I would say you want armor before you get a lift. The armor will give you the confidence to wheel without alot of damage so you can drive a little more aggressively to make up for smaller tires. x2 on armor if Rev is Gunner.
