braddaman7788
Hi I have a 2000 xj with a 94 motor that I just recently switched I of course had to change the intake manifold and exhaust manifold when I first put the motor in I could not get it to fire properly I had changed the coil for a coil pack of Eliminator where I just bought a Dodge Caravan coil pack and made my own bracket after some time of messing with that I couldn't get it to run right so I put the regular coil pack back on even though there was no where to attach it to the head the Jeep ran for about a day I drove it about 70 miles ran fine no overheating constantly held almost 60 lb of oil pressure even once warm when I went to leave work that evening I made it about 5 minutes down the road and the Jeep shut off and wouldn't continue to run running really rough falling on its face definitely some sort of fuel or fire issue upon checking I found that it was getting fuel but not fire so I replaced the crankshaft sensor then the camshaft sensor then the entire camshaft distributor oil pump Drive thing and now I've also replaced the relay that goes to the ads and I still can't get it to do anything more than fire for a few seconds by the time I shut the driver's door and walk around to the front of the Jeep it shuts off and now it won't turn over at all just cranks and cranks any suggestions would be greatly helpful
