gunner8989
- NY
Well lets first start off with myself I am very new to all this. For a year and a half I have owned a JK. Bought it brand new with all the bells and whistles. I will probably eventually sell it hence want to leave it stock, but I felt the urge to throw on a lift kit and "big meats". So I decided to go with something a little older that I can work on my own and not be to scared to mess it up a bit.
My background:
- not very mechanically inclined most ever has been oil change and radio installs but eager and willing to learn
- have been on this site and others trying to educate myself on 4x4 mods
- have some welding experience
- only ever been wheelin on a quad and drove through some fields in my JK
Ok with that out of the way lets get to my "new to me" xj and let me know what yall think!!
I want to give my JK a rest put almost 40,000 miles on it in a year and a half. So I want my XJ to be my daily driver and play thing and the JK to be like a weekender and nice day ride.
XJ
Faded Gray
88 laredo totally stock with ziebart rust proofing (tar like substance all over the underside)
148,000 miles
4.0L (242 Cu. In.) 6-Cylinder
Automatic (not sure on which auto tranny)
I used the vin decoder I found on jeepfan and the part of the vin number that indicates the tranny is not on the decoder list the letter of the vin that denotes tranny is a R if anyone knows what that indicates
4WD Cherokee Wagon 4-Door
Bought it down in Maryland for $1275 maybe some of you guys saw this one on ebay
New water Pump
New Brake Power Booster
New Front Shocks (but they look old and rear leafs are flat)
There is next to no rust on this beast, you will see in the pics that the only rust found so far is a very small amount on the lower rear corner of the rear passenger side door jam and there is some surface rust on the passenger side rocker panel, also the rear most corner near the gate on the passenger side
Everything is stock and well maintained, the reclining chairs are nice.
There is some sort of stock electrical switch for the tranny to the right of the steering column I forget the 2 options but i would guess you turn it on for more power or torque or something no idea.
Already ordered chiltons repair manual and am looking forward to getting started on the interior and bugs
Plans for this XJ will include but not limited to:
drain and flush all fluids
fix those cut wires/tubes? you'll see
rip out interior carpet then repair and rhino line or hercu line the floor
work out the bugs
new head liner
new weather stripping and rubber around windows if I can find it
'92 coolant system maybe
aux. tranny fan
suspension lift 2.5" to 3.5" not sure yet
maybe body lift 1"
rims tires don't know which size yet would like 33's
safari roof rack
install fogs
clean off factory molding and rhino line bottom 1/3
paint
maybe trim fenders but I would like to keep orig. if I can
possibly front and rear bumpers depending on bank account after everything else
Well any info or thoughts would be greatly appreciated like I said I am just getting started with all this and I need as much education as I can get.
Enjoy the pics and comment comment comment!!
Looks like shes smilin
Not bad
You can see a couple dents no big deal I'll pop em out if i can
I need an
decal on here.
A little rust bottom right in corner I pulled back the rug looks just like surface rust
looks good
not a mark
little rust here looks surface but some paint bubbles
RUST!! get out the sand paper and elbow grease
not bad
yuck needs a new headliner and dome light
My background:
XJ
Faded Gray
148,000 miles
New water Pump
work out the bugs
new head liner
aux. tranny fan
maybe body lift 1"
safari roof rack
install fogs
paint
Not bad
I need an
looks good
not a mark
not bad
