new lift, alignment specs
bluesport93
ottawa,canada
Hi guys i finally lifted the jeep 4.5 inches (RE)..
I went to the alignment shop today and id like to see what you think about the print out. 93 cherokee sport.
FRONT LEFT; camber 0.2
caster 4.3 (this number is in red)
toe 0.02
FRONT RIGHT; camber -0.2
caster 4.9 (this number is in red)
toe 0.01
TOTAL FRONT; cross camber 0.4
cross caster -0.6
cross sai 0.2
total toe 0.03
SPECIFIED RANGE CAMBER -0.8 TO 0.5
CASTER 5.0 TO 9.0
TOE -0.03 TO 0.03
Any feed back is much appreciated and thank you in advance...
How much lift? Stock lcas or adjustables? The caster has limited adjustability with stock parts, and the taller the lift the less caster you can put in without the front driveshaft pointing too far down. With you're caster set where it's at, it should still drive just fine. The rest if the numbers appear just fine.
Alignment specs for a lifted XJ are different than the stock numbers. Front pinion angle is more important than caster angle.
