I am considering putting the Aussie locker in my D30 this weekend. I read somewhere that when you pull the carrier and remove the ring gear that new ring gear bolts should be used upon reassembly. Is this necessary? If so, what kind of bolts should be used - grade 5, grade 8, something else?
In the every day world, don't worry about it. Clean the old bolts with brake cleaner, let them dry hit them with new locktite, torque to 55 ft/lbs and you are good to go.
You're going to break something else in the 30 before your ring gear bolts fail.
