New Aussie CV joint invention
Gojeep
Australia
http://www.cvcoupling.com/
Just came across this in the newspaper last night and thought some of you guys would be interested in a new CV that they say is the first ever true constant velocity without the high frictional forces of existing ones. It also can handle angles of 15-20 degrees.
  • The Thompson Coupling is as essential to our mechanised age as the screw, the crank, the lever and piston
  • The Thompson Coupling is the world's first and only Constant Velocity Joint which:
  • Has all loads carried by roller bearings
  • Has no sliding or skidding surfaces whatsoever
  • Can tolerate axial and radial loads without degradation
  • Has no torque limitation, constructed to any torque level
  • Does not require special lubrication
  • Does not require a dust boot
  • No wearing components except replaceable bearings and trunnions
  • Is suitable for automotive tail or propeller shaft applications
  • Is a true Constant Velocity Coupling as distinct from a cv joint
  • Is less bulky than a double coupling or double Cardan joint.
Very simple to see the advantages in the demos.
http://cvcoupling.com/images/stories/video/thompson_vid.wmv ( 36.6 megs )
Also states that it is less bulky than a double cardon too.
Not for steering shafts but as a replacement for double cardon and CV joints. It is actually smaller for the same torque rating than a double cardon.
I watched the video and thought it was awesome. Very good demonstrations.
I was sold on the invention, but I think it may have been that sauve australian accent that did it. :)
