New and Used XJ Parts
Moo Moo Jeep
Colonia, NJ
Most of the used parts were taken out of 4.0L, 5-speed, 4x4 Jeep Cherokee XJ (most likely 1991-1993) but some might be from different XJ/XJs. I have many more parts and I will add them gradually.
All prices OBO. Everything is located in Colonia NJ 07067. Pick up and cash preferred but I can ship smaller items if you pay shipping and 3% PayPal fee.
USED PARTS
ENGINE BAY/FUEL SYSTEM/EXHAUST
Air box $20
Compressor mount with pulley $30
Plastic battery tray $15
Metal gas tank (nice shape) $50
Rusted factory gas tank with skid plate $10 or free with gas tank
Gas tank filler neck $15
Exhaust with cat and cherry bomb muffler (some rust but in good shape) $25
Muffler. Good shape no rust. Not sure if it's from XJ but you should be able fit it in XJ. $20
SUSPENSION/STEERING/DRIVETRAIN
Rusty'strack bar and HD frame bracket. Track bar was shortened to accommodate reweldedaxle bracket. I can measure the length. $90
Powers steering box with spacer. 1 bolt broke so you'd have to drill it out. $35
Powers steering pump with bracket and hardware (it's taped to the pump). $40
Dana 44 axle shafts. Splines in good condition. I'd replace the seals. I think it'd be good idea to replace the bearings at the same time too.$100
Still have c-clip and non c-clip D35 axle shafts but they will be gone to scrap yard next week. $5 or 6 pack of Yuengling/each
MISCELLANEOUS
Beige center console $20
2" tow extension (center of the hole to COH 18"; overall length 23") $40
Spare tire-donut. Almost new still have some of the rubber "hair" on it :-) T125/90D16 $20
4 stock steel wheels 15x7 with stock Goodyear Wrangler 225/75R15 tires. 3 wheels are painted black. Tread from 30% to almost brand new. They are not matching set. They are 3 different Wrangler models. Prices from $20 to $50
Rubicon Express and Rough Country - NEW PARTS
1st price is retail or what I paid without shipping/2nd price what I'm asking.
1) RE1210 1.5 Inch Rear Lift Block & U-Bolt kit for Rear Dana 35 Axle. I might have bigger u-bolts for D44 and Ch8.25" too so if you're interested let me know I"ll find them. Same price with bigger u-bolts $78/$65
2) RE2700 Rear Shackles 1.25" lift. $98/$80
3) RE2500 Pitman Arm YJ/TJ/LJ/XJ/MJ with power steering for lifts 3.5"+. $65/$55
4) RE1550 Stainless Steel 22" Front Brake Line Set TJ/LJ/XJ/MJ/ZJ/CJ $83/$70
5) RC Front Sway-bar Disconnects Part No. 1187. for XJ and TJ. Good for lifts 4-6". $70/60
More new Rough Country npats:
Add a leaves (pins and clamps included). $70
Adjustable Lift Shackles (hardware included). Up to 2" of lift. 2 holes to to adjust height. $45
Sway Bar Drop Kit (hardware included). When you lift your Cherokee this kit relocates/lowers front sway bar without need for replacing stock sway bar links with longer ones for. $20
Shackle Relocation Kit (hardware included). It'll give up to 1.5" lift in the rear depending on which mounting point you select (it has 5 mounting points for shackles). $100
Rear extended brake line. Fits Cherokee XJ and Wrangler TJ $25
Pictures: http://s1383.photobucket.com/user/Wojciech_Luba/library/Jeep%20Parts/Cherokee%20XJ%20New%20Parts?sort=3&page=1
Update on Rubicon Express and Rough Country - NEW PARTS
More parts added
1) RE1210 1.5 Inch Rear Lift Block & U-Bolt SOLD
2) RE2700 Rear Shackles 1.25" lift. $80
3) RE2500 Pitman Arm YJ/TJ/LJ/XJ/MJ with power steering for lifts 3.5"+. $55
4) RE1550 Stainless Steel 22" Front Brake Line Set TJ/LJ/XJ/MJ/ZJ/CJ $70
5) RC Front Sway-bar Disconnects Part No. 1187. SOLD
6) Add a leaves SOLD
7) Adjustable Lift Shackles (hardware included). Up to 2" of lift. 2 holes to to adjust height. $45
8) Sway Bar Drop Kit (hardware included). SOLD
9) Shackle Relocation Kit (hardware included). SOLD
10) Rear extended brake line. SOLD
11) RC XJ front lower control arms with rubber bushings $90
12) RC 4.5" coil springs $130
13) RC 4.5" shocks $120
