new 4.0 engine in 90
itzak
Help I just put a new engine in my 90 xj and it run very well. Except going up hill when I step down on the gas then it sputters and backfires through the tail pipe. The engine was a long block all the sensors have been replaced. The throttle body has been Professionaly cleaned off the engine. Tps has been set to 13 % set off the trans side input is 4.72volts output is 4.15 Volts.It has an auto trans and the cable has been set up. also I replaced the injectors with Ford Racing 50 19 lb injectors. amy ideas?
Itzak
jneary said:
search my post and there should be one to instruct you how to do that properly, it is common especially after dist replacements
http://www.angelfire.com/my/fan/dist_index.html :D
In your case, you can miss out the removal of the valve cover step. All you need to do is slightly adjust the distributor to the position that I've described.
