Need your opinion
frontman
Cameronpark Ca
Well after changing lower hose I can only guess that the coolant leak that I have is coming from the water pump housing. I REALLY dont want to change the pump if I can avoid it, do you think bars leak will fix it or should I just buck up and change pump?
If you plan on wheeling your rig, you should replace it. It's better to prepare for Murphy's Law (anything that can go wrong, will go wrong) while in the comfort of your own home, rather than out in the middle of nowhere without access to the things you need to replace it!
Ed
buy my spacers......
then change it!
fixed, that suked but at least its done... the old pump was
"F"ed. i never want to do that again. thanx for advise ppl
quit your bitchin! :flipoff:
there is one less thing to worry about now.
