Need Torque Spec Please!
LBEXJ
NAXJA Member #721
Would someone check their FSM (or memory) and let me know what the torque spec is for the Tie Rod at the knuckle?
Thanks ...
Les
Thanks ...
Les
35 ft lbs
You still have to line up the hole for the cotter pin to go thru.
Wayne
Thanks Wayne ... I appreciate your info. I had to get this thing back together so I could go to a family get together. I ended up just torquing it down to 60 ft/lbs ... hope the threads are ok by doing that much more than 35 ft/lbs ...
I installed the Goferit Flip Bushing today and used some locktight on the threads ... there is no Castle Nut to pin.
Damn I need to fork the money out and get a FSM ...
Thanks again ...
Les
