Need some ring & pinion help
Georgia Mike
OK I need some help here. It's been about 5 years since I set up a diff, and the only other one before that was 3 years prior, so it's obvious I'm not a pro.
I'm trying to determine the source of the rumbling coming from my 8.25" rear. From what I read on Randy's R&P site, my symptoms mimicked worn carrier bearings, but upon inspection I'm thinking it was just a botched setup (symptoms are no noise until around 20 mph then I get a low rumbling noise, whether under acceleration or coasting) I did find a lot of metal shavings, so I know whatever I have going on, it's not good. I measured backlash and got a fairly loose .015", but I have zero side to side play on the carrier.
Here's what I have, and again I'm no pro so I can't just compare to a cartoon chart and say "yeah that looks fine" or "holy crap I can't believe that thing hasn't melted down yet!"
Coast side:
Drive side:
Quickly ran a magnet through the gear oil in the pan, this is what I found:
Hard to see, but as close as I could get to see the wear pattern on the drive side:
Wear pattern coast side:
After handling the carrier pin this was left on my fingers:
I looked inside the Detroit and could see no obvious damage, but I wouldn't expect there to be that would cause the noise issue I'm having.
:helpme: Any help out there?
I'm no pro either but I've never seen that much contact in the pattern.
Last time I had an obvious rumble at speed under acceleration was due to bad pinion bearings.
I'm thinking that the pinion is too high and they tried to compensate for it by pushing the carrier away from it. Either that or the big backlash number is just a product of wear, which would explain the metal in the oil.
