NEED passenger side axle shaft from dana 30
jeepinxj05
I've discovered that my passenger front wheel bearing is shot to hell (Can't drive on it at all)!! Here's the deal: At least $130 for a new wheel bearing, $70 labor (dont have access to a ginormous press, and i dont have that much. This is my Daily Driver so I started brainstorming for what i might do. What did i come up with?? Replace the entire inner/outer axle assembly on the passenger side. Now all i need to do is find the assembly, so if u have one you're not usin, please, help a jeeper out. Thanks.
why do you need a press to change a bearing hub assembly?
jeepinxj05 said:
I was told that you need quite the press to change the wheel bearings... Is this not true? But still, i think a new axle assembly is cheaper than the part...
You dont need to press them on. I have a couple sets of hubs. 60$ shipped for both driver/pass side hubs.
