Ben824
- Woodstock, GA
Ok so I have the C-Rok brace but I think I still need something more as I had to take the steering box off to replace it and I saw what I think are signs that there is still some movement in this area of the frame.
I am torn between the run-of-the-mill support that connects to the other frame rail or the Kevin's Off-Road brace that connects to both frame rails which is the only one that does this to my knowledge. My concern still is how strong the Kevin's is because it is made of only small round tube and a single mounting point on either frame rail. Their ZJ units seem to be a little beefier with two bolt mounting points and big square tubing.
Any of you guys run the Kevin's Off-Road unit before? From what I have seen it seems to be only $10-$20 more than the others.
