snail
- North Jersey
okay: 1997, 2 door, 4.0, AW4
it has an aftermarket anti-theft in it that i want to completely tear out for a number of reasons (stop right here if you are going to try to tell me to keep it 'because its there for a good reason' blah blah blah).
what it does:
1. does not allow the engine to CRANK unless a little button is pressed (only works half the time, just have to keep pressing it until it works). all electric is allowed to come on, just does not allow cranking
2. causes all the blinkers to flash in hazard mode whenever door is opened and for several seconds after engine shutoff/doors closed
3. automatically locks and unlocks the doors when engine is shutoff or when doors are closed
my concerns are i may fudge up the wiring when removing the system. here are some pics of the system, anyone have some helpful insight towards how to go about this?, or a wiring diagram ? thanks in advance, ive never dealt with these harnesses before
red circle: alarm box, blue circle: hackjob fuses, green: alarm relay?
red arrows: incorporated relay, wires running to passenger door locks?
what it does:
