greenday9d1
- CA Bay Area
I'm in the process of replacing my old broken steering gear box on my '92 XJ and it's all in except for the pitman arm. It simply refuses to go on all the way. I've aligned the splines perfectly, it slips on for about 1/2 and inch and then just stops. I cleaned the splines, greased it up, sprayed liquid wrench, but nothing seems to be working. I even tried using the puller as a pusher, hammering it with a rubber mallet, but no dice. Any ideas?
