Need Drop pitman
Why would you need a drop pitman arm for only 4.5" lift? Are you keeping stock steering?
For the time being yes. I dont plan on keeping the D30 so not sure what my steering will be when I swap axles. I have a bit of bump steer so Id like to get things lined up proper.
If you didn't drop the trac-bar at the frame or raise it at the axle then a drop pitman arm isn't going to really do you any good.
I used a ZJ arm on my 5ish lifted XJ, though I do not recall there being a difference between 4.0ZJ and 5.2ZJ... there is in the tie-rods/drag links, but I don't think the pitman arms is differnt between drivetrains.
