need a 97+ d30
Maximus
Bakersfield, CA
well the axle that I had lying around will not work on my Jeep. Way too much that wont fit just right. Someone said they had a 97+ that they would sell. I am very interested in it since I am in a very desperate state and need my Jeep to run again. Please call me on my cell at (209)815-4827 or pm me here. Thank you in advance.
Rob
Not sure if you were thinking of me, but my brother decided he wanted mine, so I hope someone esle has something for you.
I thought it was you but I couldnt remember. Rancho has one of course but it is $700 and I dont want to spend that on that right now. Any options are appreciated.
Rob,
I have a rev dana 30 non-disconnect, 297 u-jointed axles, and 4.56 gears complete for $350. I might need the calipers, though as the ones on my built dana 30 I installed have stripped bleeder screws, so I'm having a little bit of a problem bleeding my brakes. I should know pretty soon what the axle will include, it has everything but the steering, trac bar, etc. Let me know if you or someone else is interested. There isn't any difference between this axle and a 97 other than the 00' and later were low pinion and not as desirable.
Troy
Sounds great to me. The axle I have is an 88' and my existing brakes will not work with it. I would like to get it Asap if that is OK. If you can bring it to your work that would be great!! I sent the $$ for the tires tonight so you will see that soon. If the front end is complete other than the calipers that would be OK, what year is it from?
Call me in the morning and we can work out the details.
