NAXJA to be down soon... READ ME
F. F.
RELAX, this is the WEB
Here
In the near future, NAXJA will go down for maintenance.
We will be shutting the forums down on this server, and moving to a brand new server. The new server has the same Processor Specs (Dual Intel Xeon 2.8), but new RAM and new SCSI drives (current server is IDE).
With this change is a new IP address for NAXJA. The old server will be operational for a short period of time after the move while we manipulate the DNS to forward traffic to the new machine. What this will mean for some people with ISPs that cache or do not regulary update DNS records, is that you will continue to see the old server.
The "forum closed" message will include the direct IP address, so you will then be able to access NAXJA in that manner. After 24-48 hours or so, that will work itself out as ISPs update DNS records.
The actual downtime will be minimal, however the DNS transition period is out of our hands. During this time, it is possible to "lose" a few posts, though we anticipate that to be minimal.
Once this move is done, you may notice a slight improvement in speeds. Our webhost (sb-host.com) is also working on a "hardware load balancing" solution to incorporate with the NAXJA forums. The exact details are not yet worked out, but should provide some redundancy should we experience a server failure.
NAXJA continually strives to stay current on equipment to maintain a high degree of forum availability to benefit all of you.
Thank you for your patience during this transition. :)
Cliff notes:
The old NAXJA server:
And the new and improved NAXJA server:
The "changes" look like they will be happening today.
The forums will be shut down for a bit during the move, but it should not take too long (an hour or so). The forums must be shut down to keep the database intact.
For the diehards, the Members Chat will be open during the move, as it is on a separate server. If ya need your fix... use chat. :)
For many, once the files are on the new server, the changes will be immediate. Others will still reach the "old" server until their ISP updates their DNS records. Once the files are moved, access info will be provided in the "forum closed" message so that you can access NAXJA.
For those inconvenienced, apologies in advance.
Just make sure and leave Murphy behind.
Phase 1 is now done. Mostly on schedule. :)
The next phase will most likely not be noticeable for the end users. There will be the occasional slowdown, but those will mostly be late at night. It involves bringing the other server online and the hardware load balancer.
Thanks for your patience.
