loki_racer
- Pittsburgh, PA
There's a guy on base that offered to sell me his 1998 Cherokee for $200. He said he took it to the auto skills shop and the mechanic there said he needs a new oil pump (I haven't been able to confirm why the mechanic said the oil pump was the issue.
The XJ has zero leaks.
I cranked it up and it idles very rough and tries to die. It has been sitting for months without a crank. Is the rough idle likely bad fuel? Or is it likely linked to oil sending unit and/or oil pump?
I've been reading on how to determine if it's the oil sending unit or oil pump that is the problem, but haven't been able to figure out an easy way to determine which is the problem.
If the oil pump went bad and the guy drove it, how painful would that be on the engine?
