I purchased a '89 MJ Pioneer, 4.0. Pukegoat 5 speed, 3.07 gears, rear D44 and 4.5"-6" of lift. I bought it without his 33" tires and the stereo. I on put my 33x10.50-15 BFG AT's with black 15x7's with 4" of backspacing for the time being.
Here's a picture
I have a '94 and a '95 XJ that will be doners for this project. They both are 4.0 HO's with auto trannys and the '94 will supply the 242 transfer case. The '95 will supply the engine and transmission.
Some of the plans are to plate the frame, cleanup the rust on the underside and give it a good coating of rustproofing. All the factory decals and emblems will be removed, as will all the chrome trim. Only the front and rear Jeep emblems will remain on it. I will be adding power windows. locks,mirrors and my completet R134 A/C system from my '95 which has the wiring harness I will be using. I will be using my auto dimming mirror with compass from the '94 XJ.
Here it is with the first fender trimming and the cap taht came with it.(cap up for sale soon)
My front bumper
http://i120.photobucket.com/albums/o182/TNTACR/MJ005.jpg
I desided to get wilder with the front flares. I formed, reshaped, cut and fit a different flare today. It's just clamped on for right now. I also cut the fender more.
Side view
Fit at front body line
Fit at rear bodyline and filled gap
Tire coverage with 33x10.50-15 on 15x7 rims with 4" of backspacing
Another view showing the 11" of clearance over the 33" tire with 6" of lift
I still need to rework the front part of the inner fender, remove the rust, paint the fender, mount the flare and make a inner fender liner.
I stopped by a local junk yard and picked up a '77 HP D44 front and a '79 9" rear axle. My plan is 5.13 gears, lockers, alloy axles and Q78-15 Swampers.
Here's a picture
My front bumper
Side view
