rockcrawler873
- GA
Thanx again to all who have helped with the info it has helped a lot!
here are the specs on my jeep Im worriednow that my jeep is now going to perform well in road o off with the 6.5" lift and 33x12.50s and re-geared please tell me if you think i will be ok with this used as a DD and some off road?
ENGINE
GM 2.8L V6 - 115 hp @ 4800 rpm, 145 ft lb @ 2400 rpm
TRANSMISSION
Torqueflight 904 - 3 speed automatic - 86 with 2.8L V6
TRANSFER CASE
- "Command-Trac" part-time only - 2.61:1 ratio low range - used 84-87
- "Command-Trac" part-time only - 2.72:1 ratio low range - shift pattern 2H - 4H - N - 4L - used 87-01 not sure which mine is mine is a 1986 but the shift pattern is 2H - 4H - N - 4L?
REAR AXLE
Dana 35 non c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 84-89
(Note on Dana 35 axles sometimes referred to as Dana 35C - The "C" does not stand for c-clip. It stands for "custom" meaning it came from Dana unfinished.)
---Chris
ENGINE
TRANSMISSION
TRANSFER CASE
REAR AXLE
---Chris
