Matt
- Hobart, WA
I managed to get the jeep on its lid yesterday... Coming down a really steep set of rockly ledges that were slightly off camber (note to self think before a buddy says "where does that trail go")
I was creepy crawling down the last ledge just before it bottoms out into the fire road - the as weight shifted the passenger rear went from on the ground to 3 feet in the air - my first time spotter says "uh better do something" like what I would have flopped any how if had tried to pop it in reverse... so I hung on and went for a ride....
I did a slow spin on the front driver tire with the other three wheels in the air, fell onto the driver side and then onto the roof with the nose and top windshield bar supporting all the weight...
Only damage was two busted windows, (driver rear quarter window and the sunroof when some crap - namely a pitman are fell out of the center console)
I have one small dent in the halo above the quarter window where it landed first and the down tube by the rear hatch contacted the body - bent about 1/2" over a 35" span...
I may see if I can pull that out... Probably replace the sunroof with plex and just pick up an extra window... All in all the cage did exactly what it was designed to do...
We spun it in the road on its lid and then rolled it back onto all four - flat towed it back to the main pit filled the oil and pulled the #1 plug to see if the was any oil in the cylinders - spun it over with no coil wire and nothing came out - replace the plug and it started up the first time - no problems
Aired up the tires, rigged some plastic sheet for the sunroof and drive it home...
Matt
Matt
