My cheap jeep winter (400$)
projectTK
Swantucky
Hello all. I bought this jeep from my neighbor for 400$ It was his backyard beater and mudder. (i live out in the country) 89xj 5spd peugot 3.07 gear 29 muffet tires on 16inch rims. No exhaust, speedo gauge and front headlight are the only things that worked. Pictures say it all.
Next to my crossfire for a visual on the height (4.5 rancho lift)
Intake routed in cab, dash sawed in half, one broken seat, lots of mudd on floor, holes in floor
that mudd is on the inside of the window. lol!
The motor is somewhat clean. Egr and pollution shit blockoff, electric fan to a switch in the inter fender. No manual fan. overheats later to find out there was barely any coolant.
Junkyard finds.. New grille and headlights, seats, the hole dash and wires including fuse box and some more
Ripped seats out and look at all that dirt
So i powerwashed out the inside of my jeep
Sanded down. holes sheet metaled and pop riveted shut, painted with truck bedliner aerosal
New fender because the old one was so dented mud came in the cab
i bet those really sling the mud!!!!!!
lots of tools
New heater core, shut up the holes made to route intake in cab
Prepped for paint
1st coat
Had to swap all the wires out of the hacked harness into the new harness because of the manual speedo cable. Lots o wires.
After the 10cans of bedliner aerosal and alot of good fumes!!:woohoo:
All buttoned up, oil and temp gauge mounted in center console, blower motor runs off a toggle and so does the electric fan, everything else works
Looks awsome totally different
31inch wild spirit tires 15x10 inch black rim
i bought it for 400$ and i came close to about 2000$ spent alll in all in this project
Me stuck
Well it is still an on going project. It is my dd in bad weather. I runs and drives good. I also put a new track bar in, new clutch kit, new rad, coolant bottle, thermostant, all new fluids, to much to list. Later i ran into 2 owners ago and he told me when he had it he put a newer motor in it. He put a renix with 80000miles in it then. So the motor its self has probably under 100000miles because it was never street legal. Now it is. I plan to add 33inch tires, aw4 tranny with external slave, either a dana 44 or 8.25 with a rear locker and 456's. Any comments or questions feel free to ask.
97XJ Jeeper said:
whats the deal with that round metal pan thing?
Unless I miss my guess, that would be the new air intake.
if u look at the engine pic the previous owner routed a rv gutter hose and cut a hole in the firewall on passenger side and threw the second wall where the glove box is now and put a round airfilter with a pan style top on it with a wing nut. But i wanted a full dash. I now have it routed up out the top of the cowl grille on the passenger side. Il put pics up tommarow.
you should have left the tractor tires on it, maybe you wouldn't have been stuck:twak:
nah, just razzin ya some, great find nice jod on the rebuild;)
got a welder or a friend with a welder?
if so, put an 8.8 in it and regear that.
then you're ready for the larger tires and you got disc brakes.
the pumpkin will drag a lot with 31's though.
15x10s is a little too much rim imo.
them rounds lights werent in a supported bucket they just dangled all over. The stickers dont bother me i just toke the redneck one off. As for the holes i patch them with sheet metal and pop riveted it to the floor and bed linered over. I dont have any carpet for the simple reason of getting water in the cab and having moldy carpet. Bedliner is durable enough.
